NetApp Stage KB
SnapCenter LUN creation fails when TLS 1.0 and 1.1 are disabled
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Server
Issue
Attempting to create or connect a LUN from the SnapCenter UI or PowerShell generates an error stating that no storage connection is set for the storage system.
In the SCW Debug log a similar entry is generated:
2019-10-23T15:33:49.3182483-06:00 Verbose SDW PID=[XXXX] TID=[XXXX] The client and server cannot communicate, because they do not possess a common algorithm
2019-10-23T15:33:49.3182483-06:00 Verbose SDW PID=[XXXX] TID=[XXXX]    at System.Net.SSPIWrapper.AcquireCredentialsHandle(SSPIInterface SecModule, String package, CredentialUse intent, SecureCredential scc)
   at System.Net.Security.SecureChannel.AcquireCredentialsHandle(CredentialUse credUsage, SecureCredential& secureCredential)
   at System.Net.Security.SecureChannel.AcquireClientCredentials(Byte[]& thumbPrint)
   at System.Net.Security.SecureChannel.GenerateToken(Byte[] input, Int32 offset, Int32 count, Byte[]& output)
   at System.Net.Security.SecureChannel.NextMessage(Byte[] incoming, Int32 offset, Int32 count)
   at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
   at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
   at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at System.Net.ConnectStream.WriteHeaders(Boolean async)
2019-10-23T15:33:49.3182483-06:00 Error SDW PID=[8968] TID=[10684] The underlying connection was closed: An unexpected error occurred on a receive.   at SnapDrive.Nsf.Common.Infrastructure.RestClient.Invoke[TReq,TRes](TReq request, String methodType, String remoteUrl, Boolean dataContractSerializer)
   at SnapDrive.Service.SDServiceManagerHelper.InitializeRBACCache()"
New to NetApp?
