NetApp Stage KB
SnapCenter Enumeration and backup issue of one SQL failover cluster node
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
  • SnapCenter Server (SC)
Issue
Users have encountered issues where only the disks from the primary host of the cluster are visible within SnapCenter.
Additionally, backups cannot be performed from the node where disks are not all visible.
When refreshing the host disk in Snapcenter, the Discovery job is showing errors in the log
2024-04-09T13:05:26.2158895+02:00 DEBUG SCW_30315 PID=[8820] TID=[32] GetHostFileSystem: -> Sending Scsi inquiry \\?\Disk{<diskid>},\\?\Volume{<volume id>}\
2024-04-09T13:05:26.2158895+02:00 ERROR SCW_30315 PID=[8820] TID=[32] sendSCSI failed. Exception - CreateFile failed. Error: 2
2024-04-09T13:05:26.2158895+02:00 DEBUG SCW_30315 PID=[8820] TID=[32] scsiGetAddress: caught exception '2'
Message : Object reference not set to an instance of an object.
Source : SnapDrive.Nsf.Core.Host
StackTrace : at SnapDrive.Nsf.Core.Host.HostDiscoveryManager.GetHostFileSystem(String host, Boolean isAlm)
New to NetApp?
