NetApp Stage KB
SnapCenter DB2 backup is getting failed with error: SCC-00161: Application unquiesce for the plug-in DB2 failed with exit code -1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter server 6.0
  • SnapCenter Plug-in for DB2
Issue
SnapCenter DB2 backup is getting failed with below error:
2024-11-06T16:03:11.0000253+11:00 ERROR  [pool-7-thread-159] 118 com.netapp.plugincreator.workflow.task.UnQuiesce -SCC-00161: Application unquiesce for the plug-in [DB2] failed with exit code [-1] and error :
Command execution failed with error:
SQL1551N  The SET WRITE RESUME command or the RESTART DATABASE command with
the WRITE RESUME parameter failed because of the condition that is indicated
by the reason code. Reason code = "2".
DB20000I  The SQL command completed successfully.
Same DB is mounted with different Alias name and one as remote:
2024-11-06T16:03:01.0000855+11:00 DEBUG  [pool-45-thread-1] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -Starting execution of the command : [/bin/sh, -c, sudo /opt/NetApp/snapcenter/scc/bin/sccCommandExecutor DB_Test1 'sqllib/bin/db2 \"LIST DATABASE DIRECTORY\";']
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - System Database Directory
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Number of entries in the directory = 2
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -Database 1 entry:
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database alias                       = DB_Alias_2
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database name                        = DB_Test1
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Node name                            = N1RG1SSL
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database release level               = 15.00
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Comment                              =
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Directory entry type                 = Remote
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Authentication                       = SERVER
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Catalog database partition number    = -1
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Alternate server hostname            =
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Alternate server port number         =
2024-11-06T16:03:03.0000284+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -Database 2 entry:
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger -
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database alias                       = DB_Alias_1
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database name                        = DB_Test1
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Local database directory             = /db2/db2_data/db2regi1/dcapregk/data
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Database release level               = 15.00
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Comment                              =
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Directory entry type                 = Indirect
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Catalog database partition number    = 0
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Alternate server hostname            =
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger - Alternate server port number         =
2024-11-06T16:03:03.0000285+11:00 DEBUG  [Thread-232] 100 com.netapp.snapcenter.plugin.DB2.DB2Logger –
New to NetApp?
