NetApp Stage KB
SnapCenter Custom Plugin backups fail after working successfully previous day
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Custom Plugin (SCC)
  • SnapCenter Plug-in for Oracle (SCO)
Issue
  • Daily SCC backups fail after working successfully previous day.
  • If the service is restarted, first new backup will succeed but then subsequently fail
  • If service is not restarted,the following errors may occur:
SCC-00164: Application quiesce for the plug-in [DB] failed with exit code [1] and with error :
sudo: sorry, you must have a tty to run sudo
SCC-00161: Application unquiesce for the plug-in [DB] failed with exit code [1] and error :
SCC-00185: Cleanup for the plugin [DB] failed with the exit code [102] and error :
New to NetApp?
