NetApp Stage KB
SnapCenter 6.0 PowerShell Integration Issues
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • SnapCenter Server 6.0.0
  • PowerShell 7
Issue
With the release of SnapCenter 6.0, there have been significant changes to the PowerShell Toolkit. These changes have introduced two primary issues:
  1. PSModulePath Not Populated: The PSModulePath environment variable is not consistently populated during the upgrade or installation process.
  2. Manual Module Import Requirement: Users now need to manually import the SnapCenter module, which was previously auto-loaded.
Detailed Description:
Issue 1: PSModulePath Missing
During the installation of Powershell 7, the PSModulePath environment variable is not always updated to include the path to the modules folder.
Issue 2: Manual Module Import Requirement
In SnapCenter 6.0, the auto-import functionality that was available in previous versions does not work anymore. Users now need to manually import the SnapCenter module using the Import-Module command. This change requires users to adjust their scripts to include the module import command at the beginning.
New to NetApp?
