NetApp Stage KB
SnapCenter 5.0 Install fails with fatal error during installation
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server (SC)  4.9 and above
  • MySQL Server
Issue
  • Fresh installation of SnapCenter 4.9 or 5.0 fails returning GUI fatal error during installation.
  • MySQLInstaller log error:
Install MySQL Server.Log: Installation : Starting process for MySQL Server 8.0.35...
Install MySQL Server.Log: Installation : Starting process with command: C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe --defaults-file="C:\ProgramData\NetApp\SnapCenter\MySQL Data\my.ini" --console --initialize-insecure=on --lower-case-table-names=2...
Install MySQL Server.Log: Installation : /-\|C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe (mysqld 8.0.35) initializing of server in progress as process 5508
Install MySQL Server.Log: Installation : Unknown suffix '.' used for variable 'mysqlx-port' (value '0.0').
Install MySQL Server.Log: Installation : option 'mysqlx-port': unsigned value 0 adjusted to 1.
Install MySQL Server.Log: Installation : C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe: Error while setting value '0.0' to 'mysqlx-port'.
Install MySQL Server.Log: Installation : Parsing options for plugin 'mysqlx' failed.
Install MySQL Server.Log: Installation : InnoDB initialization has started.
Install MySQL Server.Log: Installation : /-\|/-\|/-\|/InnoDB initialization has ended.
Install MySQL Server.Log: Installation : -\|/-\|/-\|/-\|/unknown variable 'mysqlx_port=0.0'.
Install MySQL Server.Log:: ERROR: SET PASSWORD: Exception: Can't connect to MySQL server on 'localhost' (10061):
No connection could be made because the target machine actively refused it 127.0.0.1:3306
Install MySQL Server.Log:: ERROR: SET PASSWORD: Failed.
 Main Log: MySQL Community Installation completed successfully.
New to NetApp?
