NetApp Stage KB
SMBR fails to authenticate
3
Visibility:
Votes:
0
Category:
single-mailbox-recovery-smbr
Specialty:
SNAPX
Last Updated:
Applies to
  • Single Mailbox recovery (SMBR) 8.3
  • SnapCenter Server 4.3 and later
Issue
The SnapCenter authentication wizard reports that SMBR fails to authenticate to the remote Exchange Server:
Authentication failed: If trying to connect to a remote Exchange Server please provide a valid Exchange Server name or IP address when authenticating
The following warning may be present in the Application Event Logs on the SMBR server:
Level: Warning
Event: 300,
Source: PowerShell(PowerShell)
Provider Health: WinRM cannot process the configuration request.  The hostname pattern "*" is invalid.  Hostname patterns must contain one or more patterns.  A pattern can contain at most on wildcard ("*").  The special pattern "<local>" can be used to indicate all hostnames that do not have a ".".  To trust all hosts use "*" as the only pattern.
New to NetApp?
