SC fails to delete snapshot during applying retention with remove snapshot error: 102
Applies to
SnapCenter Server (SC)
Issue
- SC backup jobs attempt to apply retention and fails with error
Remove SnapShot failed Error: 102 <installation_path>\Program Files\NetApp\SnapCenter\SMCore\SnapDriveSALDebug.loghave the following entries:
Command starts: Remove-NcSnapshot -Volume <volume> -Snapshot <snapshot_name>
Verbose SAL PID=[7152] TID=[4504] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: entry doesn't exist
Verbose SAL PID=[7152] TID=[4504] Remove Snapshot <snapshot_name> on <volume> is failed. Error: 102- These can be logged hundreds of times during backup job and the length of the backup job can grow from a few minutes in duration to as much as few hours.
