NetApp Stage KB
SCV intermittent backup failure - Failed to discover entities in resource group
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plugin for VMware (SCV)
Issue
  • SCV backup jobs intermittently fail with error, "Failed to discover entities in resource group"
  • The SCV vmcontrol job log shows an exception was returned when querying VMware for the datastore property associated with the VM:
YYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager          : [JobId:XXXX] Found datastore with config file: DS_NAME. Checking for datastore in metadata.
YYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager          : [JobId:XXXX] Datastore already populated in metadata, checking for vm: VM_NAME
YYYY-MM-DD HH:MM:SSSS DEBUG SCV --- [p474675244-5236] c.n.a.d.VsphereDiscoveryManager          : [JobId:XXXX] Datastore already contains vm in metadata
YYYY-MM-DD HH:MM:SSSS  WARN SCV --- [p474675244-5236] c.n.a.d.StorageDiscoveryManager          : [JobId:XXXX] java.lang.RuntimeException: com.vmware.vijava.vim25.ManagedObjectNotFound
at com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:158)
at com.vmware.vijava.vim25.mo.ManagedObject.getCurrentProperty(ManagedObject.java:179)
at com.vmware.vijava.vim25.mo.ManagedObject.getManagedObjects(ManagedObject.java:221)
at com.vmware.vijava.vim25.mo.ManagedObject.getManagedObjects(ManagedObject.java:268)
at com.vmware.vijava.vim25.mo.ManagedObject.getDatastores(ManagedObject.java:273)
at com.vmware.vijava.vim25.mo.VirtualMachine.getDatastores(VirtualMachine.java:60)
at com.netapp.aegis.vsphere.VirtualMachineService.getDatastoresForVM(VirtualMachineService.java:1623)
New to NetApp?
