NetApp Stage KB
SCV fails to create/update resource group due to NumberFormatException
2
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • NetApp Data Broker
  • SnapCenter Plug-in for VMware vSphere (SCV) 4.3 or later
  • ONTAP 9
Issue
  • The resource group is abnormal about the time is NaN status in the Data Broker after VMotion some VMs out from this resource group via the ESXi vSphere client.
  • Edit the resource group shows "Field cannot be empty" alert.
  • After hitted the Finish button on the Edit Page, the errors pop up Failed to create/update the resource group and java.lang.NumberFormatException: For input string: “NaN”.
New to NetApp?
