NetApp Stage KB
SCV does not rotate backup Snapshots with retention due to insufficient free memory
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server 4.1.1
  • SnapCenter Plug-in for VMware vSphere (SCV) 4.1.1
Issue
  • SCV backup Snapshots are not deleted by retention.
  • SMCore_<JOB_ID>.log shows RegisterBackups gets Internal Server Error (500) in the task Registering Backup and Applying Retention.
INFO  SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Activity - Registering Backup and Applying Retention,  Starting
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RegisterMetadataActivity Started
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RemoteUrl: https://<SNAPCENTER_SERVER_URI>:8146/BackupMetadataService.svc/RegisterBackups
INFO  SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] SmWebClient : webRequest.ServicePoint.ConnectionLimit set to 1500
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] WebException in method: Invoke.
System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
   at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request)
   at System.Net.WebClient.UploadString(Uri address, String method, String data)
   at SnapMgrHelper.RestAdapter.Invoke[TReq,TRes](TReq request, String methodType, String remoteUrl, Boolean dataContractSerializer, Boolean isAuthorized, Boolean logRequest, Boolean logResponse)
Additional information:
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Invoked service successfully
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] Exception in method: Execute.
   at SnapMgrHelper.SmsRestHelper.Invoke[TReq,TRes](String methodType, TReq request, String serviceName, String method, Boolean xmlContentType)
   at SnapMgrCoreService.Workflows.Common.Backup.RegisterMetadataActivity.Execute(SmWorkflowContext workflowContext, SmRequest request) : Detailed Exception The remote server returned an error: (500) Internal Server Error. : BaseException System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
ERROR SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] ErrorCode (-1), ErrorMessage (The remote server returned an error: (500) Internal Server Error.)
DEBUG SMCore_<JOB_ID> PID=[<PID>] TID=[<TID>] RegisterMetadataActivity Done
  • SnapManagerWeb_<JOB_ID>.log shows the task Registering Backup and Applying Retention is failed.
DEBUG SnapManagerWeb_<JOB_ID> PID=[<PID>] TID=[<TID>] Updating the job (<JOB_ID>) task (Registering Backup and Applying Retention) status as Failed
  • Application event log indicates the following error message. The service '/BackupMetadataService.svc' cannot be activated due to System.InsufficientMemoryException.
WebHost failed to process a request.
 Sender Information: System.ServiceModel.ServiceHostingEnvironment+HostingManager/10501549
 Exception: System.ServiceModel.ServiceActivationException: The service '/BackupMetadataService.svc' cannot be activated due to an exception during compilation.
 The exception message is: Memory gates checking failed because the free memory (XXXXXXXXX bytes) is less than 5% of total memory. As a result, the service will not be available for incoming requests.
 To resolve this, either reduce the load on the machine or adjust the value of minFreeMemoryPercentageToActivateService on the serviceHostingEnvironment config element..
 ---> System.InsufficientMemoryException: Memory gates checking failed because the free memory (XXXXXXXXX bytes) is less than 5% of total memory.  As a result, the service will not be available for incoming requests.
   at System.ServiceModel.Activation.ServiceMemoryGates.Check(Int32 minFreeMemoryPercentage, Boolean throwOnLowMemory, UInt64& availableMemoryBytes)
   at System.ServiceModel.ServiceHostingEnvironment.HostingManager.CheckMemoryCloseIdleServices(EventTraceActivity eventTraceActivity)
   at System.ServiceModel.ServiceHostingEnvironment.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath, EventTraceActivity eventTraceActivity)
   --- End of inner exception stack trace ---
   at System.ServiceModel.ServiceHostingEnvironment.EnsureServiceAvailableFast(String relativeVirtualPath, EventTraceActivity eventTraceActivity)
 Process Name: w3wp
 Process ID: <PID>
New to NetApp?
