SCV 5.0: Failed to add/update storage system(s) information when editing settings
Applies to
- SnapCenter Plug-in for VMware vSphere (SCV) 5.0
- SnapCenter Plug-in for VMware vSphere (SCV) 5.0P1
Issue
- When trying to edit the Cluster or SVM credentials to update the password or re-enter it (to refresh SVM information) after the upgrade, the following error occurs for clusters entries:
(X) Failed to add/update storage system(s) information.
Failed to add/update storage system information:
Object reference not set to an instance of an object.- After removing the Cluster-LIF and attempting to add it back in to bypass this issue, the error has changed to:
Failed to add/update storage system information: Failed to connect to storage system <SVM_NAME_OR_IP_ADDR>.\n
This instance has already started one or more requests. Properties can only be modified before sending the first request.- Not able to connect to SVMs and list the volumes after upgrade of SCV. .
Failed to add/update storage system information: Failed to connect to storage system <SVM_NAME_OR_IP_ADDR> .\nInvalid credentials. Please check the username or password
