SCSQL verification failing with OS error: 5(Access is denied.)
Applies to
- SnapCenter Server (SC)
- SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
Issue
- Remote verification with SCSQL is failing with the following alert seen in the Event logs:
Alert: MSSQL on Windows: Failed to open primary database file
Source: mssql_server\MSSQLSERVER
Path: Not Present
Last modified by: System
Last modified time: 2023-06-19 16:06:54
Alert description: Event ID: 17204. FCB::Open failed: Could not open file C:\scmnpt\<disk_path>.ldf for file number 0. OS error: 5(Access is denied.).
The username is valid and has the correct permissions:
DEBUG SmSql_800673 PID=[2616] TID=[38] verifying backup of database: [instance\database]
DEBUG SmSql_800673 PID=[2616] TID=[38] Using host auth [domain\instance] to connect to SQL instance: [instance_name]
DEBUG SmSql_800673 PID=[2616] TID=[38] Connecting to SQL Server: [server_name]
DEBUG SmSql_800673 PID=[2616] TID=[38] Host auth is valid, and it has sysadmin privileges.
