NetApp Stage KB
SCSQL restore or clone from secondary storage fails or hangs
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 4.8P1
  • SnapCenter Plug-in for Windows (SCW) 4.8P1
  • SnapCenter Plug-in for VMware vSphere (SCV) 4.8
Issue
  • Restoring a SCSQL backup located on secondary storage (SnapMirror / SnapVault) fails.
  • Cloning from a SCSQL backup located on secondary storage (SnapMirror / SnapVault) results in the Clone from backup wizard hanging on the Clone Options screen.
In both scenarios, the following error messages can be seen:
SMCore_<Job_ID>.log
ERROR SMCore_<Job_ID> PID=[5256] TID=[299] mount snapshot failed Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
DEBUG SMCore_<Job_ID> PID=[5256] TID=[299] Exception in clone storage Mount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
ERROR SMCore_<Job_ID> PID=[5256] TID=[299] ErrorCode (-1), ErrorMessage (Mount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
DEBUG SMCore_<Job_ID> PID=[5256] TID=[299] Activity name: Cloning snapshot <Snapshot_Name>: -1 - Mount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
ERROR SMCore_<Job_ID> PID=[5256] TID=[299] Exception in PerformClone Mount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
ERROR SMCore_<Job_ID> PID=[5256] TID=[299] Exception in CloneVirtualandStorageResource Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
ERROR SMCore_<Job_ID> PID=[5256] TID=[299] ErrorCode (-1), ErrorMessage (Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
SAL_<Job_ID>.log
Error SAL PID=[5256] TID=[12060] None of the host initiators <Initiator1_WWPN> <Initiator2_WWPN1> <iSCSI_Target> are logged into the controller. Resolution: Please make sure the supplied inititators are logged in.
New to NetApp?
