NetApp Stage KB
SCSQL plug-in upgrade fails with "Another instance of this setup is already running"
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • Snapcenter Server
  • Snapcenter Plugin for SQL
Issue
SnapCenter plug-in for SQL upgrade fails with following error.
*** InstallShield suite engine (Unicode) started
Engine: we're running from C:\Users\xxxx~1\AppData\Local\Temp\{D19500D8-C05C-4C9A-B77E-695F16650B9A}\_isAC26.exe
Engine: running with elevated privileges: yes
Initializing engine...
Engine: setup will run silent
Engine: parsing setup.xml
Bootstrap engine exception: 80040711
Another instance of this setup is already running. Please wait for the other instance to finish and then try again.
New to NetApp?
