NetApp Stage KB
SCSQL database clone lifecycle job disabled by Snapcenter
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Server (SC) 4.5
  • SnapCenter Plug-in for Microsoft SQL Server (SCSQL) 4.5
  • Clone LifeCycle job (CLC)
Issue
  • There were 2 CLC jobs configured. One is at Resource Group (RG) level and the other at database (DB) level with the database in the DB CLC job part of the RG CLC
  • SC disables the database CLC job in Windows Task Scheduler on the SC server host
  • No error seen in logs although the disable entry can be seen in the SMCoreService.log on the SC server host
    DEBUG SMCore PID=[4244] TID=[27] Start calling SchedulerTaskAction
    DEBUG SMCore PID=[4244] TID=[27] ExecuteTaskAction starts
    DEBUG SMCore PID=[4244] TID=[27] For hostname = localhost jobname = SnapCenter_<RG_ID>_POLICY-<PolicyID/Name>, task action = Disable
    DEBUG SMCore PID=[4244] TID=[27] Changing Windows scheduler: <CLC_ResourceGroupName_Policy>
  • When the RG CLC is deleted or DB CLC is edited, causes the DB CLC to be disable. This can only be enabled manually in the Task Scheduler
New to NetApp?
