SCSQL/SCV database verification and clone operations to a remote SQL server located on a remote ESX cluster fails
Applies to
- SnapCenter Server
- SnapCenter Plug-in for VMware vSphere [SCV]
- SnapCenter Plug-in for SQL Server [SCSQL]
Issue
- SCSQL/SCV database verification and clone operations to a remote SQL server located on a remote ESX cluster fails " An error occurred while cloning RDM based disk. Failed to Map virtual disk: Invalid configuration for device '0'."
Error SDW PID=[PROCESS ID] TID=[TASK ID] Failed to delete virtual disk: Error Deleting Raw Device Mapping - could not find the Raw Device mapping on ESX Server at VirtualizationAPI.CVirtualServer.UnmapVirtualDisk(String strLunSerialNo, Boolean bOwner, Boolean bEsxIscsi) at SnapDrive.Nsf.Core.VMWareHelper.DeleteRawDeviceMapping(String strLunSerialNo, Boolean bOwner, Boolean bIsEsxISCSI) Verbose SDW PID=[PROCESS ID] TID=[TASK ID] --VMWareHelper::DeleteRawDeviceMapping
Error SDW PID=[PROCESS ID] TID=[TASK ID] Failed to delete virtual disk. Details: Failed to delete virtual disk: Error Deleting Raw Device Mapping - could not find the Raw Device mapping on ESX Server 2018-02-14T08:06:02.8827438-08:00 Verbose SDW PID=[PROCESS ID] TID=[TASK ID] -- VMWareRDMProvisioningStrategy::DeleteVirtualDiskLocally 2018-02-14T08:06:02.8827438-08:00
Error SDW PID=[1700] TID=[3540] Failed to delete virtual disk. Details: Failed to delete virtual disk:
Error SDW PID=[PROCESS ID] TID=[TASK ID] An error occurred while cloning RDM based disk.
