SCSQL Cloned Database Compatibility Level Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:2Visibility:PublicVotes:0Category:snapcenterSpecialty:SNAPXLast Updated: Applies to SnapCenter Server (SC) SnapCenter Plugin for SQL (SCSQL) Issue SnapCenter SQL database backup does not reflect current compatibility level configuration after clone operation.
