NetApp Stage KB
SCO restore fails because of missing Oracle parameters file
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • NetApp SnapCenter 4.7
  • NetApp SnapCenter For Oracle (SCO) plugin 4.7
Issue
When restoring an Oracle database, it failed with the following error:
YYYY-MM-DDThh:mm:ss+01:00 ERROR SMCore_XXXXX PID=[XXXX] TID=[XX] ErrorCode (-1), ErrorMessage (PL-SCO-25000: Pre-Restore of database files failed with error: ORACLE-20001: Error trying to change state to STARTED for database instance TEST: ORACLE-00001: Error executing SQL: [STARTUP NOMOUNT;].  The command returned: ORA-01078: failure in processing system parameters)
New to NetApp?
