NetApp Stage KB
SCO install/upgrade fails with error "No Java virtual machine could be found from your PATH environment variable"
2
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter
  • SanpCenter Plug-in for Oracle (SCO)
Issue
When attempting to upgrade or install the SnapCenter Unix based Plug-ins, it fails with the following error:
No Java virtual machine could be found from your PATH environment variable.
You must install a VM prior to running this program.
New to NetApp?
