NetApp Stage KB
SCO failed configure Oracle database settings XML document (1, 57)
3
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for Oracle (SCO)
Issue
When adding Linux host error Failed – Configure oracle database settings: There is an error in the XML document (1, 57) is received from database configuration settings
SMCoreService.log
ERROR SMCore PID=[5276] TID=[53] Exception in method: InvokeXML.
System.InvalidOperationException: There is an error in XML document (1, 57). ---> System.InvalidOperationException:
<SmResponse xmlns=''> was not expected.
spl-log.txt
WARN DRes-PROD c.n.c.p.u.OperatingSystemImpl - PLAT-00020: Unable to load native process library.
Error: no com_netapp_common_platform_unix_FileSystemNativeImpl in java.library.path
java.lang.UnsatisfiedLinkError: no com_netapp_common_platform_unix_FileSystemNativeImpl in java.library.path
New to NetApp?
