NetApp Stage KB
SCHANA fails to quiesce database
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for SAP HANA
Issue
SCC-00164: Application quiesce for the plug-in [hana] failed with exit code [-1] and with error : Verification of DB [path_to_DB] failed with error: ['"path_to_DB"' is not recognized as an internal or external command,operable program or batch file.]. Set valid DB_Name parameter for the Plug-in for SAP HANA Database on this host by running "Set-SmConfigSettings -Plugin -HostName hostname -PluginCode hana -configSettings @{"DB_Name"="path_to_DB"} " PowerShell cmdlet from the SnapCenter Server.
New to NetApp?
