NetApp Stage KB
Registering Backup and Applying Retention task of SCW backup job fails in WSFC
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for Microsoft Windows(SCW)
  • Windows Server Failover Clustering(WSFC)
Issue
  • Registering Backup and Applying Retention task of SCW backup job by error
Backup Registration : RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
  • SnapManagerWeb.log shows Cannot find object '<HOST><FILESYSTEM_PATH>:\' from database
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] FillBackupMetaData started
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Components:1, Successful:1 & Failed:0
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Cannot find object '<HOST><FILESYSTEM_PATH>:\' from database
ERROR SnapManagerWeb_28 PID=[5424] TID=[5] System.NullReferenceException: Object reference not set to an instance of an object.
   at SnapManager.SMSDAL.BackupMetadataMapper.GetBackupComponentInfo(SmRequest request, SmBackupComponentInfo bci, nsm_BackupToObjects_map& nsm_bom, Int64 userId, Boolean isMigrationRequest, Boolean updateSecondaryDetails)
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Object reference not set to an instance of an object.
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] GetBackupComponentInfo - <HOST><FILESYSTEM_PATH>:\
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] FillBackupMetaData Done
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] MapSMBackupToEntities ended
ERROR SnapManagerWeb_28 PID=[5424] TID=[5] ErrorCode (-1), ErrorMessage (RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo )
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterResourceOwner - <HOST><FILESYSTEM_PATH>:\
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] Unable to find in nsm_sm_object
DEBUG SnapManagerWeb_28 PID=[5424] TID=[5] RegisterBackupEntities failed (PrimaryBackup): RegisterBackupEntities failed : BackupMetadataMapper:FillBackupMetaData Problem filling up BackupComponentInfo
  • <HOST> is not listed in Hosts > Disks even after executing Refresh Disks
New to NetApp?
