NetApp Stage KB
Plug-in installation fails due to one or more minimum requirements missing
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for Microsoft SQL Server (SCSQL)
Issue
  • Plug-in installation fails due to one or more minimum requirements missing on the host
  • Errors seen in the upgrade log in C:\Windows\SnapCenter plugin on the plug-in host:
Product: SnapCenter Plug-in for Microsoft SQL Server -- Error 1920. Service Plug-in for SQL Server Service (SCSQLPluginService) failed to start.  Verify that you have sufficient privileges to start system services.
(ISP Action): SILENT INSTALL : ERROR : Unable to complete the installation.
(ISP Action): SILENT INSTALL : ERROR : Check for error in the logs and retry the installation.
(ISP Action): SILENT INSTALL : ERROR : Aborting the setup.
Action 'CA_Abort_Install' returned status 0x80070643
Original exit status: 0x80070643, final exit status: 0x00000643
New to NetApp?
