NetApp Attach VMDK fails with ERROR Reconfig VM Task failed during SCV restore job
Applies to
SnapCenter Plug-in for VMware vSphere (SCV) 4.4
Issue
- NetApp Attach VMDK fails with
ERROR:- Reconfig VM Task failedduring SCV restore job vmcontrol_<JOB_ID>.logandvmcontrol_jetty_server.logshowsERROR:- Reconfig VM Task failed
ERROR <HOST> --- [ Thread-88] c.n.a.v.VirtualMachineService : [JobId:<JOB_ID>] ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX
ERROR <HOST> --- [ Thread-88] c.n.a.r.VmdkRestoreManager : [JobId:<JOB_ID>] Error attaching VMDK to Virtual Machine <VM>"
ERROR <HOST> --- [ Thread-88] c.n.a.s.AegisApiServiceImpl : Error attaching VMDK to Virtual Machine <VM>"
INFO SCV root com.netapp.nvpf.api.model.ApiException: ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX
INFO SCV root at com.netapp.aegis.vsphere.VirtualMachineService.addExistingDiskToVm(VirtualMachineService.java:560)
INFO SCV root at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdkFromBackupUsingVmdkFilePath(VmdkRestoreManager.java:364)
INFO SCV root at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdksToVM(VmdkRestoreManager.java:311)
INFO SCV root at com.netapp.aegis.server.AegisApiServiceImpl$6.run(AegisApiServiceImpl.java:1273)
INFO SCV root at java.lang.Thread.run(Thread.java:748)
INFO SCV root at com.netapp.aegis.vsphere.VirtualMachineService.addExistingDiskToVm(VirtualMachineService.java:568)
INFO SCV root com.netapp.nvpf.api.model.ApiException: ERROR:- Reconfig VM Task failed: XXXXXXXXXXXXXXXXX. You can manually attach the disk from the cloned datastore(s). Add the scsi controllers manually and try again.
INFO SCV root at com.netapp.aegis.restore.VmdkRestoreManager.attachVmdksToVM(VmdkRestoreManager.java:334)
