Is a capacity-based license required for SnapCenter 6.0 and Cloud Volumes ONTAP?
Applies to
- SnapCenter Server (SC) 6.0
- Cloud Volumes ONTAP (CVO)
Answer
No, a capacity-based license is not required for SnapCenter 6.0 and Cloud Volumes ONTAP.
NOTE:
No change has been made to the SnapCenter UI, so if a capacity-based license was previously added, the following will still be seen in the SnapCenter UI:
- Controller License for CVO under ONTAP Storage Connections will still show as
Not Applicable
- Licensed Capacity widget will still show the licensed capacity of the previously added license
- This is merely visual - if the licensed capacity is exceeded, everything will continue to function as it should
