NetApp Stage KB
Failed to access guest system using specified credentials, when trying to restore a file in a VM from the SnapCenter vSphere Plugin
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Plug-in for VMware (SCV) 4.0-4.1.1
  • NetApp Data Broker (NDB)
  • SnapCenter Plug-in for VMware (SCV) 4.3 and higher
Issue
Error messages trying to run Guest File Restore:
Failed to access guest system using specified credentials.
Please verify VMWare tools is installed/running on the system and account used has domain administrator privileges.
Error is ApiException Failed to start process in guest system SystemError vix error codes = (3004, 0).
Seen in  vmcontrol_jetty_server.log:
com.netapp.nvpf.api.model.ApiException: Failed to access guest system using specified credentials.
Verify if VMWare tools is installed or running on the system and the account is built-in administrator account. Error is ApiException  Failed to start process in guest system InvalidGuestLogin
New to NetApp?
