NetApp Stage KB
Discovery after adding Oracle Host fails to find a Database for backup
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for Oracle (SCO) 4.9, 5.0
Issue
After successfully deploying the SCO Plug-in to a Linux Host (SLES 15, RHEL 7 or 8), the discovery fails to access the database with name <SID> logging the following error in the spl_<JOBNUMBER>.log from the Discovery Job:
DEBUG Execution Monitor Thread [sudo /opt/NetApp/snapcenter/spl/bin/sc_command_executor root ls -l /oracle/<SID>/18.0.0/bin/sqlplus | cut -d" " -f3] c.n.c.e.ShellResult - EXE-00001: Shell result [0:00:00.104] (Exit Value: 0):
ls: cannot access '/oracle/<SID>/18.0.0/bin/sqlplus': No such file or directory
In 5.0(P1) you may also see the following message, since it was trying to find the user and group owning the sqlplus:
ERROR c.n.p.s.u.OraclePluginUtil - PL-SCO-20032: canExecute operation failed with error: An exception thrown during the execution of method setOracleOwnerAndGroup and the exception message is Command executed successfully with no output..
       com.netapp.sco.smcore.plugin.exception.PluginExecutionFailedException: An exception thrown during the execution of method setOracleOwnerAndGroup and the exception message is Command executed successfully with no output..
Or followed by, depending on chosen Oracle Authentication method (database versus operating system):
ERROR        DRes-PZ2 c.n.o.c.c.AbstractDatabaseService - JDBC exception from AbstractDatabaseService:
   ORACLE-00510: Failed to find environment details for database SID.
com.netapp.oracle.core.common.OracleException: ORACLE-00510: Failed to find environment details for database SID.
New to NetApp?
