NetApp Stage KB
Disconnect-SdStorage hangs and fails to remove virtual disk
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter
  • SnapDrive
Issue
  • Attempt at disconnecting mount points using Disconnect-SdStorage -path <mountpoint_path> -IgnoreVolumeMountPoint hangs and fails at removing virtual disks
  • Error below can be seen in the logs
2024-06-10T17:36:05.0059533-04:00 Verbose SDW PID=[4352] TID=[3740] --VMWareHelper::DeleteRawDeviceMapping
2024-06-10T17:36:05.0059533-04:00 Error SDW PID=[4352] TID=[3740] Failed to delete virtual disk: A general system error occurred:  PBM error occurred during PostProcessReconfigureSpec: pbm.fault.PBMFault   at SnapDrive.Nsf.Core.VMWareHelper.DeleteRawDeviceMapping(String strLunSerialNo, Boolean bOwner, Boolean bIsEsxISCSI)
at SnapDrive.Nsf.Core.VMWareRDMProvisioningStrategy.DeleteVirtualDiskLocally(SDFilesystem fileSystem, String lunPath, String storageSystem)
New to NetApp?
