Clone Lifecycle job fails with "Failed to mount storage resource, error is Failed to create the volume clone.'"
Applies to
- SnapCenter Server [SC]
- SnapCenter Plug-in for SQL [SCSQL]
- Data ONTAP 9.14.1 and prior versions.
Issue
- SCSQL Clones randomly failing in SnapCenter with error :
Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.'
- SMCore logs:
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] --PSHelper::RunCommand
2024-03-29T04:30:51.8943418-05:00 ERROR SMCore_103293 PID=[3676] TID=[36] Failed to create volume clone
