NetApp Stage KB
Can the throughput of auto QoS ANF capacity pools be edited using Trident?
1
Visibility:
Votes:
0
Category:
astra_trident
Specialty:
SNAPX
Last Updated:
Applies to
  • Astra Trident 24.06
  • Azure NetApp Files (ANF)
  • Auto QoS Capacity Pools
Answer
  • No, it is not possible to edit / increase the throughput of auto QoS ANF capacity pools using Trident.
  • Trident does not support manual QoS ANF capacity pools.
  • Trident uses the backend configuration (subnet, virtual network, service level, and location), to create Azure NetApp Files volumes on capacity pools that are available in the requested location and match the requested service level and subnet.
  • The throughput of the capacity pool is then determined by ANF, using a combination of the following factors:
    • The service level of the capacity pool to which the volume belongs
    • The quota assigned to the volume
    • The QoS type (auto or manual) of the capacity pool
