NetApp Stage KB
Auto Discovery for plug-in MySQL failed with error and exit code 102
1
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Custom Plug-in for MySQL
Issue
After installing the plugin in this case Redhat 8, fails to discover the DB, adding the resource manually and run a backup will fail with the following error:
2020-11-25T11:05:22.0000788+01:00 ERROR [pool-3-thread-5] 187 com.netapp.plugincreator.workflow.util.TaskUtil -Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
2020-11-25T11:05:22.0000788+01:00 ERROR [pool-3-thread-5] 268 com.netapp.plugincreator.workflow.Task -Operation failed. Reason: The watchdog killed the running operation. Verify that plugins/wrapper/wrapper binary has execute permission set. Increase the WRAPPER_TIMEOUT_IN_MSEC value in agent.properties if operations require more time to complete.
2020-11-25T11:05:22.0000788+01:00 ERROR [pool-3-thread-5] 116 com.netapp.plugincreator.workflow.task.AppDiscoveryTask -SCC-00155: Auto Discovery for plug-in [MySQL] failed with error [] and exit code [102]. Exiting.
New to NetApp?
