NetApp Stage KB
CSNAPC-9695: SC 6.x - All PostgreSQL instances have the same name (postgres_5432)
14
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Issue
  • All PostgreSQL instances / clusters are named the same when added to SnapCenter, if:
    • The PostgreSQL server being added has multiple instances, that use the same service name and port
    • Multiple PostgreSQL servers are added, that use the same service name and port
    • Example:
      • If the default service name of postgres and the default port of 5432 are used, the instance / cluster name created in SnapCenter would be postgres_5432
  • This makes it difficult to distinguish which instance / cluster is running on which server.
New to NetApp?
