NetApp Stage KB
What are the ports used by OnCommand Insight?
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight
Answer
Port conflict causing issues with functionality of OnCommand Insight (OCI).
LOCAL ONLY indicates that a port will accept communication only from a source on the same machine.
Acquisition
  • 9009 [TCP] LOCAL ONLY Acquisition JMX console
  • 9010 [TCP] LOCAL ONLY Acquisition JMX console
  • 12123 [TCP] LOCAL ONLY
  • 162 - [UDP] SNMP traps (Not mandatory)
Server
  • 80 [TCP] HTTP access
  • 443 [TCP] Primarily Acquisition to server access
  • 1097 [TCP] JNDI (naming) - lookup of components in the server
  • 1098 [TCP] JNDI (naming) - lookup of components in the server
  • 1099 [TCP] JBoss
  • 4444 - [TCP] JMX
  • 4445 - [TCP] JMX
  • 8083 - [TCP] JBoss WebService SOAP
  • 8086 - [TCP] SOAP Monitor Port
  • 8090 - [TCP] JBossMQ
  • 8092 - [TCP] JBossMQ
  • 8093 - [TCP] JBossMQ
MySQL
  • 3306 [TCP] Server to MySQL communication Acquisition (work in progress).
    Note: Not all the ports are needed. Only the ports that relate to one of the data sources used in your system are required.
  • 161 - [UDP] Sphereon, Cisco, Brocade
  • 162 - [UDP] Sphereon, Cisco
  • 1521 - [TCP] ECC StorageScope
  • 2001 - [TCP] Hitachi HiCommand & HP Command View
  • 2707 - [TCP] SymAPI
  • 6389 - [TCP] CLARiiON CLI
  • 59520 - [TCP] SWAPI
  • 59521 - [TCP] SWAPI
  • 51510-51513 - [TCP] EFCM/ConnectrixManager
  • 22  [TCP] NetApp, Brocade
  • 80, 4092, or 8088 - [TCP] NetApp - Uses one of the following ports depending on configuration.
  • 80, 443 - CommandView, VMware
  • 2301, 12301, 2372 - HP EVA
  • 5999 - IBM SVC SMI-S & 3PAR SMI-S
  • 22 - IBM SVC CLI & 3PAR CLI
  • 5988, 5989 - SUN SMI-S
3997 - Incipient
Note: Refer to the Support Matrix embedded in the code of OCI.
See the OnCommand Insight Installation and Administration Guide for the latest port requirements for your version of OCI.
