OnCommand Insight Data Warehouse reporting portal is not accessible - refused to connect
Applies to
- OnCommand Insight Data Warehouse 7.3.10 +
Issue
When trying to access the OnCommand Insight Data Warehouse reporting portal you receive the following error.
This site can’t be reached
dwh-reporting.server.com refused to connect.
- When trying to start
DB2 - DB2COPY1 - DB2-0service you receive the following error.
The DB2 - DB2COPY1 - DB2-0 service failed to start due to the following error:
The service did not start due to a logon failure.
- The Windows Event Viewer - System shows the following error
The DB2REMOTECMD_DB2COPY1 service was unable to log on as .\db2admin with the currently configured password due to the following error:
Logon failure: the user has not been granted the requested logon type at this computer.
Or
The DB2-0 service was unable to log on as .\db2admin with the currently configured password due to the following error: The password for this account is expired.
- The below error can resolved by adding
db2adminaccount to the local WindowsAdministrator group
The DB2 - DB2COPY1 - DB2-0 service failed to start due to the following error: Access is denied
