NetApp Stage KB
OnCommand Insight DWH ETL pre capacity job fails on Datamarts Preparation step
3
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
om
Last Updated:
Applies to
  • OnCommand Insight Data Warehouse 7.3.13 (OCI DWH)
  • Microsoft Windows Server 2012 R2 Standard
  • Extract, Transform, Load (ETL)
Issue
  • dwh.log (here truncated) shows the error as below for failed Datamarts Preparation step:
2022-02-16 01:10:47,095 ERROR [Thread-14 (ActiveMQ-client-global-threads)] JobDispatcherBean (JobDispatcherBean.java:135) - Job{name='Datamarts Preparation', id=42757} failed
com.netapp.sanscreen.dwh.capacity.CapacityException: Failed running pre capacity job
at com.netapp.sanscreen.dwh.dmstaging.generate.DMStagingRunnerBean.dumpStagingAreaAndRethrow(DMStagingRunnerBean.java:93)
at com.netapp.sanscreen.dwh.dmstaging.generate.DMStagingRunnerBean.run(DMStagingRunnerBean.java:80)
Caused by: com.netapp.sanscreen.dwh.capacity.CapacityException: Failed to clean capacity staging area
Caused by: com.netapp.sanscreen.dwh.util.SqlShellException: Failed to execute: DROP DATABASE IF EXISTS dwh_cloud_cost_staging
Caused by: java.sql.SQLException: Schema 'dwh_cloud_cost_staging' does not exist, but schema directory '.\dwh_cloud_cost_staging\' was found. This must be resolved manually (e.g. by moving the schema directory to another location).
  • NOTE: Schema name can be other "xxx_staging" but the root cause/solution will be same if the log output is as above.
New to NetApp?
