NetApp Stage KB
OCI 7-Mode datasource intermittent gap in IOPS graphs
2
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
Oncommand Insight 7.3.5 (OCI)
NetApp 7-Mode datasource
Issue
Customer found intermittent gap in IOPS 7-Mode performance report.
The error seen in logs is as follows,
2021-03-18 10:50:13,475 ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] Datasource [Error connecting] - Failed to connect to ZAPI at: datasource IP, check IP/port connectivity and assert ZAPI configuration. ([Device name 19X.XX.XX.XX]: Failed to connect to ZAPI at: datasource IP:80, check IP/port connectivity and assert ZAPI configuration.)
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Failed to connect to ZAPI at: datasource IP:80, check IP/port connectivity and assert ZAPI configuration.
at com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException.createWithEnhanced(DataSourceErrorException.java:67) ~[au.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_192]
Caused by: java.net.ConnectException: Connection timed out: connect
New to NetApp?
