NetApp Stage KB
Netgroup auto resolution success rate is low in OCI, when using a domain user
1
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
om
Last Updated:
Applies to
OnCommand Insight 7.3.14 latest Service Pack (OCI)
Issue
  • In OCI, the autoresolution success rate is getting low once switching from local to domain user on discovering the ONTAP datasource
  • This happens if the netgroups are residing on the LDAP/NIS
  • In the recording we see calls returning 0 results, where they shouldn't
  1. Running ZAPI to CLI command to enter in diag mode, which succeeds:
<<< REQUEST >>>^M
system-cli|||priv=diagnostic,args=set;-privilege;diagnostic^M
^M
<?xml version="1.0" encoding="UTF-8" standalone="no"?>^M
<netapp xmlns="http://www.netapp.com/filer/admin" version="1.0">^M
<system-cli>^M
<priv>diagnostic</priv>^M
<args>^M
<arg>set</arg>^M
<arg>-privilege</arg>^M
<arg>diagnostic</arg>^M
</args>^M
</system-cli>^M
</netapp>^M
^M
<<< REQUESTEND >>>^M
<<< RESPONSE >>>^M
HTTP/1.1 200 OK^M
  1. Running seqid show -name <netgroup_name> in diag mode, returns 0 results
<<< REQUEST >>>^M
system-cli|||priv=diagnostic,args=debug;seqid;show;-name;km03v33_p_nas^M
^M
<system-cli>^M
<args>^M
<arg>debug</arg>^M
<arg>seqid</arg>^M
<arg>show</arg>^M
<arg>-name</arg>^M
<arg>km03v33_p_nas</arg>^M
</args>^M
</system-cli>^M
</netapp>^M
^M
<<< RESPONSE >>>^M
HTTP/1.1 200 OK^M
Date: Wed, 07 Feb 2024 13:26:19 GMT^M
Server: libzapid-httpd^M
X-Content-Type-Options: nosniff^M
Cache-Control: no-cache, no-store, must-revalidate^M
Deprecation: true^M
Content-Length: 265^M
Content-Type: text/xml^M
Keep-Alive: timeout=5, max=37^M
Connection: Keep-Alive^M
^M
<?xml version='1.0' encoding='UTF-8' ?>
<!DOCTYPE netapp SYSTEM 'file:/etc/netapp_gx.dtd'>
<netapp version='1.221' xmlns='http://www.netapp.com/filer/admin'>
<results status="passed"><cli-output></cli-output><cli-result-value>0</cli-result-value></results></netapp>
  1. Then we feed the results of above command to getXXbyYY command on the -c parameter, which results in 0 results.
<<< REQUEST >>>^M
system-cli|||priv=diagnostic,args=systemshell;-node;km03n03;-command;getXXbyYY;getnetgr_bulk;-c;null;4096;share_km03v03_vol00004_080525_root^M
^M
<system-cli>^M
<args>^M
<arg>systemshell</arg>^M
<arg>-node</arg>^M
<arg>km03n03</arg>^M
<arg>-command</arg>^M
<arg>getXXbyYY</arg>^M
<arg>getnetgr_bulk</arg>^M
<arg>-c</arg>^M
<arg>null</arg>^M
<arg>4096</arg>^M
<arg>share_km03v03_vol00004_080525_root</arg>^M
</args>^M
</system-cli>^M
</netapp>^M
^M
<<< RESPONSE >>>^M
HTTP/1.1 200 OK^M
Date: Wed, 07 Feb 2024 13:26:20 GMT^M
Deprecation: true^M
Keep-Alive: timeout=5, max=100^M
^M
<results status="passed"><cli-output></cli-output><cli-result-value>0</cli-result-value></results></netapp>^M
<<< RESPONSEEND >>>
New to NetApp?
