Known issues that can cause installation failure of Data WareHouse; Resolution Guide
Applies to
Data WareHouse (DWH) installation
Solution
This KB article contains hyperlinks to known issues that can cause installation or upgrade issues for Data Warehouse Server
| Verify the Windows host meets basic minimum requirement |
Make sure the Windows OS meets OCI server minimum requirements
Make sure all of the Ports outlined in the DWH Minimum requirements are available on the Windows host. |
Ensure Windows driver is installed that allows MYSQL Database to operate |
| AntiVirus Exclusions |
| The OCI installation directory must be excluded from Antivirus software scans |
| Use the correct user when installing DWH |
| Windows user must have Administrator privileges, as outlined in the OCI WIndows installation instructions |
| Linux User must have SUDO privileges, as outlined in the Linux installation instructions |
| DWH DB2 user / service prevents DWH install |
| Data WareHouse Installtion issues caused by DB2 User or DB2 services Resolution Guide |
| Installation Drive configuration prevents installation |
| OnCommand Insight Data Warehouse 7.3.X install fails because 8dot3 naming convention is not enabled on the installation drive |
| Multiple install attempts |
| OCI_DWH_fails_due_to_remnants_on_the_file_system |
If installation issues are not resolved by the articles in this resolution guide, Collect Logs from the Data Warehouse and open a NetApp Technical Case for further assistance.
Additional Information
Known issues that can cause installation failure of OnCommand Insight; Resolution Guide
