NetApp Stage KB
ElasticSearch indexing failures cause performance issues in OnCommand Insight
4
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.x
Issue
Issues that may be related to failed indexing in ElasticSearch are listed below. These may be seen together or separately.
  • Slow WebUI searches
  • High CPU usage on the OCI server
  • High Memory usage on the OCI server
  • File system near full/full on the OCI server
  • 404 Page Not Found error message when trying to access the WebUI
  • Datasources failing with error "Internal error: Cannot update server (Server returned HTTP response code: 500 for URL"
In the server_indexer.log (located in \SANscreen\wildfly\standalone\log) you may see failed index messages similar to:
2018-01-15 20:35:00,436 ERROR [EJB default - 7] QueryIndexBuilder (QueryIndexBuilder.java:195) - Error indexing InternalVolume
 com.netapp.oci.es.ElasticsearchException: [bulkIndexById][INDEX_NAME:oci-inventory-internalvolume-2018-01-15-20-33] [ANOMALY_INDEX_TYPE: internalvolume] [IDS: [7864440,
 Caused by: com.netapp.oci.es.ElasticsearchException: Error bulk indexing data. failure in bulk
execution:
 [19439]: index [oci-inventory-internalvolume-2018-01-23-07-56], type [internalvolume], id [11609
24], message [java.lang.IllegalArgumentException: Document contains at least one immense term
in field="annotationValues.text.Automounter Path" (whose UTF8 encoding is longer than the max l
ength 32766), all of which were skipped. Please correct the analyzer to not produce such terms. T
he prefix of the first immense term is: '[47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 114, 103,
98, 44, 32, 47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 98, 108, 97]...', original message: by
tes can be at most 32766 in length; got 37802]
In server.log (located in \SANscreen\wildfly\standalone\log) you may see failed messages similar to:
2019-06-18 07:11:26,296 ERROR [default task-33057] OriginatorWorkingSet(OriginatorWorkingSet.java:488) - <datasource> failed on submit, due to: Errors encountered while executing delete extendedData documents. failure in bulk execution:
[0]: index [oci-extended-data-v2], type [_doc], id [1871197], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[1]: index [oci-extended-data-v2], type [_doc], id [3310508], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[2]: index [oci-extended-data-v2], type [_doc], id [1567170], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[3]: index [oci-extended-data-v2], type [_doc], id [4478203], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[4]: index [oci-extended-data-v2], type [_doc], id [4311330], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
In the oci-cluster.log (located in \SANscreen\program_data\elasticsearch\logs) you may see failed messages similar to:
[2018-03-26T17:55:13,054][WARN ][o.e.c.a.s.ShardStateAction] [<datasource>] [oci-timeseries-qtree-2018-03-11][1] received shard failed for shard id [[oci-timeseries-qtree-2018-03-11][1]], allocation id [sSKYeTqNR46jrWY-rGw1XA], primary term [0], message [failed recovery], failure [RecoveryFailedException[[oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ {TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}]; nested: IndexShardRecoveryException[failed recovery]; nested: IllegalStateException[pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]]; ] org.elasticsearch.indices.recovery.RecoveryFailedException: [oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ}{TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}
Caused by: org.elasticsearch.index.shard.IndexShardRecoveryException: failed recovery
 at org.elasticsearch.index.shard.StoreRecovery.executeRecovery(StoreRecovery.java:299) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.StoreRecovery.recoverFromStore(StoreRecovery.java:88) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.recoverFromStore(IndexShard.java:1238) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.lambda$startRecovery$1(IndexShard.java:1486) ~[elasticsearch-5.4.2.jar:5.4.2]
 ... 4 more
Caused by: java.lang.IllegalStateException: pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]
New to NetApp?
