Data Warehouse DB2 user or DB2 Service stops access to Cognos reporting portal Resolution Guide
Applies to
- OnCommand Insight Data WareHouse (DWH)
- Cognos (DWH reporting portal)
- DB2 user account
- DB2 Services
Solution
This Resolution guide provides provides information related to gaining access to DWH reporting portal (Cognos), as related to issues originating from DWH DB2 user or DB2 Services.
Note:
- For DWH versions 7.3.10 and later, the service account will be the DB2 admin user set during install (db2admin by default)
| Cognos Services are dependent on DB2 Services |
OnCommand Insight Data WareHouse reporting portal is not accesible - Refused to connect |
| Verify user configured for the DB2 Service |
| Cognos service cannot start on Data Warehouse 7.3.10 with VGS-SRV-1002 Failed to clear the local cache |
| Windows Reboot policy prevents DB2 service start |
| After restarting the OnCommand Data Warehouse services IBM Cognos does not start |
