NetApp Stage KB
Is there a way to compare 2 Clusters' configuration?
4
Visibility:
Votes:
0
Category:
not set
Specialty:
om
Last Updated:
Applies to
  • ONTAP 9
  • Active IQ Digital Advisor
  • Config Drift
Answer
  • There is no way to compare 2 clusters' entire configuration.
Note: ONTAP does not have the function to compare or export the entire configuration in a readable form.
  • ASUP-based comparisons are possible.
    • Active IQ Digital Advisor presents Config Drift.
    • Config Drift creates a template from an Autosupport.
    • It is possible to compare configurations from the AutoSupport of the same or different system against this created template.
Note: To use this function, the following cotracts are required.
  • Support Edge Premium
  • Support Edge Secure
  • Support Edge Advisor
  • PartnerSelect
  • PartnerSelect Foundation
  • Support Edge Expert
Additional Information
additionalInformation_text
