How to generate an Upgrade Advisor plan via Active IQ Digital Advisor
Applies to
- Active IQ Digital Advisor
- Upgrade Advisor
- ONTAP 9
- Upgrade Advisor
- Is a feature within Active IQ Digital Advisor
- Will help you determine
- If your system can be upgraded to a specific version you desire
- The correct path to reach this version
- It may require multiple upgrades depending on the target release
- Digital Advisor may only show the first hop if multiple upgrades are required.
- Known risks or check points along the way
Note: Upgrade Advisor requires an AutoSupport bundle to create the report. If you don't have Autosupport enabled by default, follow How to manually upload AutoSupport messages to NetApp
