NetApp Stage KB
Active IQ Digital Advisor displays "None" for efficiency on SVM root volumes
2
Visibility:
Votes:
0
Category:
active-iq-digital-advisor
Specialty:
om
Last Updated:
Applies to
  • Active IQ Digital Advisor (AIQDA)
  • ONTAP 9
Issue
  • When looking the "Efficiency" tab for a cluster within the Active IQ Digital Advisor the "Enabled Efficiency" column doesn't show the correct efficiency for specifically SVM root volumes.
  • In the image below the volumes svm_blue_root, svm_red_root, svm_green_root all show "None" in the "Enabled Efficiency" when they should display "Deduplication".
  • When confirming on the ONTAP cluster side we can see that efficiency is enabled for the volume(s).
  • In the example below we can see that the two non-root volumes are "Enabled" but svm_blue_root is missing.
netapp01-01::> volume efficiency show -vserver blue_svm
Vserver    Volume           State     Status      Progress           Policy
blue_svm
           blue_lun1 Enabled   Idle        Idle for 855:22:46 auto
blue_svm
           blue_lun2 Enabled   Idle        Idle for 855:10:05 auto
2 entries were displayed.
  • This can be interpreted as a misleading scenario.
New to NetApp?
