NetApp Stage KB
Acquisition failed for all clusters in AIQUM due to maximum connection limit exhaustion
3
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • ActiveIQ Unified Manager (AIQUM) 9.6+
  • All OS platforms
  • ONTAP 9.x
Issue
  • Intermittently acquisition is failing for all clusters added to AIQUM
  • Cluster Monitoring Failed and Cluster Not Reachable alerts are triggered by AIQUM
  • However, the acquisition starts working automatically after sometime or if triggered manually
  • All the prerequisites like AV exclusions and resources availability in terms of CPU/Memory/Disk space are applied on the AIQUM
  • SSL certificates for AIQUM as well as the ONTAP clusters are valid
  • AIQUM au.log:
ERROR [common-pool-2064] c.o.s.a.d.n.NetAppOCIEArchivePerformancePackage (NetAppOCIEArchivePerformancePackage.java:381) - Failed to get archive file names from zapi. java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.waitForConnect(Native Method) ~[?:?]
Wrapped by: com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Failed to connect to <cluster IP/Hostname>
at com.onaro.sanscreen.acquisition.datasource.netapp_ocie.transport.zapi.ZAPIConnection.createDefaultNaServer(ZAPIConnection.java:803) ~[au-datasource-netappfoundation.jar:9.13.0-2023.09.J299]
ERROR [common-pool-2064] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - <cluster_IP/Hostname> [Error connecting] - Failed to connect to <cluster IP/Hostname> (connect timed out)
  • AIQUM ocumserver.log:
ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Socket connection error for cluster: <cluster IP/Hostname> java.net.ConnectException: Connection timed out: connect
ERROR [oncommand] [reconciliation-0] [c.n.d.c.ClusterStatusListener] Cluster : <cluster IP/Hostname> is not reachable. Generating cluster not reachable event.
New to NetApp?
