NetApp Stage KB
AIQUM acquisition unit receives authentication error even though correct credential is set
5
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM) 9.12 and later
  • ONTAP 9.6 and later
  • Enabled Mutual Transport Layer Security (mTLS / Mutual TLS) for ONTAP cluster
Issue
  • Even though a cluster credential is correct, acquisition unit is unable to collect data from ONTAP due to authentication error
  • AIQUM DASHBOARD shows Cluster discovery failed. Rediscover the cluster after resolving the issue.
  • Event Cluster Monitoring Failed is triggered
  • au.log shows errors:
ERROR [common-pool-XX] c.o.s.a.d.n.t.z.ZAPIConnection (ZAPIConnection.java:629) - [netappfoundation] <cluster_name> - while executing ZAPIs on datasource: <cluster_name> IP: <cluster_ip> for ZAPI: system-get-version, netapp.manage.NaAuthenticationException: Authorization failed netapp.manage.NaAuthenticationException: Authorization failed
ERROR [common-pool-XX] c.o.s.a.f.d.BaseDataSource (DataSourceErrorException.java:246) - cluster1 [Invalid login credentials] - Failed to log in to the cluster: <cluster_name> ([Device name <cluster_name>]: Failed to login to the cluster.)
  • /etc/log/mlog/apache_logs/apache_error.log of ONTAP cluster shows authentication error for user null
[auth_basic:error] [pid <pid>:tid <tid>] [client <AIQUM_IP>:<port>] AH01617: user null: authentication failure for "//servlets/netapp.servlets.admin.XMLrequest_filer": Password Mismatch
New to NetApp?
