After AIQUM 9.10p1 or 9.11 upgrade ONTAP or GCP CVO will not allow single file restore
Applies to
- Active IQ Unified Manager (AIQUM 9.10p1 & 9.11)
- ONTAP 9.x
- Google Cloud Provider (GCP)
- Cloud Volumes OnTap cluster (CVO)
- file restore via AIQ Unified Manager restore utilizing NDMP
Issue
- When attempting to add a new GCP cluster or do a single file or folder restore from GCP cluster then it would fail with the following error in "Restore job" in UI.
Could not find cluster management IP address for cluster
- In logs
ocum-error.log
will show the same exact error message as well
2022-05-11 09:01:32,768 WARN [q377465] [job-475] [Restore Job|restore-meta-task] [c.n.dfm.protect.ndmp.NdmpCopyUtil] The cluster mgmt lif : 10.10.10.10 has been found but not reachable
2022-05-11 09:01:32,768 ERROR [q377465] [job-475] [Restore Job|restore-meta-task] [com.netapp.dfm.job.JobEngine] Error executing job 3de2f28198175335:-273a8be:18022548719:-7f4e task 3de2f28198175335:-273a8be:18022548719:-7f4f: Could not find cluster management IP address for cluster 'clustername'.
java.lang.RuntimeException: Could not find cluster management IP address for cluster 'clustername'.
at deployment.dfm-app.war//com.netapp.dfm.protect.ndmp.NdmpCopyUtil.getClusterMgmtIpAddress(NdmpCopyUtil.java:656)
...<truncated>
at deployment.dfm-app.war//com.netapp.dfm.job.JobEngine$$EnhancerBySpringCGLIB$$df70b928.process(<generated>)
at deployment.dfm-app.war//com.netapp.dfm.workqueue.WorkerThread.run(WorkerThread.java:44)
2022-05-11 09:01:32,792 INFO [q377465] [job-476] [Restore Job|FINISH] [com.netapp.dfm.job.FinishTask] Completed job in 0:00:02.083
