NetApp Stage KB
CAIQUM-6159: Adding Cluster to AIQUM 9.14 failing with exception if ONTAP 9.14.1 cluster have SAML enabled
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
Not able to add a cluster in AIQUM 9.14 if ONTAP 9.14.1 cluster have enabled SAML with error:
YYYY-MM-DD HH:MM:SS ERROR [SAML_user] [default task-3] [c.n.d.o.o.OntapMutualAuthenticationManager] Exception installing Mutual TLS certificate on ONTAP
com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 13 path $
New to NetApp?
