NetApp Stage KB
CAIQUM-6132: Unable to install AIQUM 9.13/9.14 on Windows
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Issue
  • Installation of Active IQ Unified Manager (AIQUM) 9.13 and 9.14 on Windows host
    with error:
    Failed to start MYSQL service. Refer log more more details. Setup will terminate now !!!
  • C:\ProgramData\MySQL\MySQLServerData\Data\error.log reports error:
    [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    [System] [MY-010116] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe (mysqld 8.0.34) starting as process 5172
    [ERROR] [MY-000058] [Server] Unknown suffix '.' used for variable 'mysqlx-port' (value '0.0').
    [Warning] [MY-000081] [Server] option 'mysqlx-port': unsigned value 0 adjusted to 1.
    [ERROR] [MY-000077] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe: Error while setting value '0.0' to 'mysqlx-port'.
    [ERROR] [MY-010746] [Server] Parsing options for plugin 'mysqlx' failed.
    [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
    mysqld: Table 'mysql.plugin' doesn't exist
    [ERROR] [MY-010735] [Server] Could not open the mysql.plugin table. Please perform the MySQL upgrade procedure.
    [Warning] [MY-010441] [Server] Failed to open optimizer cost constant tables
    [Warning] [MY-010015] [Repl] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened.
    [Warning] [MY-010068] [Server] CA certificate ca.pem is self signed.
    [System] [MY-013602] [Server] Channel mysql_main configured to support TLS. Encrypted connections are now supported for this channel.
    [ERROR] [MY-013129] [Server] A message intended for a client cannot be sent there as no client-session is attached. Therefore, we're sending the information to the error-log instead: MY-001146 - Table 'mysql.component' doesn't exist
    [Warning] [MY-013129] [Server] A message intended for a client cannot be sent there as no client-session is attached. Therefore, we're sending the information to the error-log instead: MY-003543 - The mysql.component table is missing or has an incorrect definition.
    [ERROR] [MY-000067] [Server] unknown variable 'mysqlx_port=0.0'.
    [ERROR] [MY-010119] [Server] Aborting
    [System] [MY-010910] [Server] C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe: Shutdown complete (mysqld 8.0.34) MySQL Community Server - GPL.
New to NetApp?
